Mike96
Separate PDF files from multiple layouts
I know how to render multiple layouts into a single PDF file, but how to export them to separate PDF files in one go - one single-page file per layout? I know there are external programs to split multi-page PDFs into many single-pagers, but it would be welcome if we could do it inside Archicad, like we can do in Revit, without needing to use any extra soft.
I'm using AC 25. Maybe it's in newer versions?
Operating system used: Windows 10
ArchiCAD 25
Windows 10
1 Solution
Assuming you are using Publisher to create the PDF files?
If so just turn off the option to 'merge to one PDF file'.
Go to post
6 Replies 6
Mike96
Oh, I didn't know this option existed. Thank you!
ArchiCAD 25
Windows 10
Zendrix
Hi Barry!
Apparently i am struglling to find out why i have no such button on my "publisher" menu!!
Z
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
Lpalma
Check that you have the "Create a real folder structure" or "Create flat file structure" option selected in publisher set properties. That could be it.
Lpalma
Zendrix
Hey! Thanks for answering. I have, as i show in the picture. Can't seem to figure it out...
Z
Zendrix
Somehow i found it!
Thanks!
Z
