ā2025-04-30
05:17 PM
ā2025-04-30
08:49 PM
The "Split schedule into multiple layouts" command is currently very limited. It only splits a schedule into identical layouts, without changing the content based on filters or categories like floor levels.
For example, if I want to show the quantities for each floor on separate sheets, I have to manually create a separate schedule for each floor. This means duplicating the schedule 10 times for 10 floors, which is repetitive and inefficient.
It would be much more useful if we could add separators or groupings within a single schedule, based on parameters like floor or level. That way, one schedule could automatically update and display data for all floors, while still keeping each floor's data clearly separated. This would save a lot of time and reduce the need for creating and managing multiple schedules manually.
ā2025-04-30 06:25 PM
I agree. We have had issues with splitting long schedules to multiple layouts. You could submit a "Wish" in the Wishes section if you don't find a decent solution.
