‎2018-02-25
07:26 PM
‎2025-02-07
11:19 AM
Aruzhan Ilaikova
‎2018-02-25 09:17 PM
‎2018-02-25 10:07 PM
uisanata wrote:I am not using the built-in marker of the window.
We are using an Autotext label that extracts a custom property from the Property Manager instead of the built-in Marker.
‎2018-02-25 10:26 PM
‎2018-02-26 02:35 PM
uisanata wrote:The OptionSet sounds like a solution. The only disadvantage that I see here is the number of elements to choose in the Option set. For a door you would have way too much because it must be a combination for E or EI, the insulation index 1 or 2, times 30-60-90-120, selfclosing Yes/No and Smokestop Yes/No. Or you define just some basic values, and then it is the duty of a project leader to extend the OptionSets.
I have only one property for walls, doors, windows and other building elements that require fire safety, data type is an Option Set with all possible values.
‎2018-02-26 04:28 PM
‎2018-02-26 05:54 PM
