2026-06-03 01:17 PM
Hi, is it possible to use the keyword <LAYOUTCUSTOMPAR2> in a gdl parameter?
2026-06-04 08:51 AM
Autotext cannot be used within parameters, they can only be displayed as is. You might be able to request it, but I have not looked into it.
Ling.
2026-06-05 01:17 AM
is that a property? I don't know how/why you would need it in a gdl text... I suppose if you have a property, you could have a text field that linked to autotext in the gdl script.
If, for example, you save an autotext field in a text box as a custom label, when that label is attatched to something, the autotext would read that property value from the element it is linked to. But if it isn't a label, I don't think there are any straight forward ways to link it to a property value of an element.
2026-06-05 03:14 PM
What I want to do is a bit advanced, it seems to me, I want to create a 2D gdl object to place in the master layout that reads the status of the project placed in custom par 2 of the layout
2026-06-05 05:20 PM
No object can read the values of any other object or anything else placed in another layout.
Not without having one object write data to a text file and then having the second object read that text file.
But there are issues with this as it does not always update when you want it to.
You can set anything on a layout as a 'Reference' and then you can use autotext to access certain values of that reference, but it is only things like the layout page number that reference is on.
These are the available reference values, I don't think this is what you are looking for.
2026-06-08 03:37 AM
"status of the project placed in custom par 2 of the layout"?
If it is information stored within each layout, why not just use the default Layout Status input? Not quite sure how it is retrieved, but the default Revision History Detailed object uses it, so you could delve into that to see how it works.
Ling.
2026-06-08 06:20 PM
i wil give it a try
2026-06-09 02:28 PM
Custom Layout or ProjectInfo Autotexts can be accessed via their UID. You can find the corresponding UIDs by exporting the Layout Book settings or the Project Info.
then call it in 2D-Script
parname = "<custom-LAYOUT-01B3CFFF-1390-364C-9732-08145042B324>"
2026-06-10 03:04 AM - edited 2026-06-10 03:05 AM
There must be a more generic way, else the Revision History object would not work... Like some way to request an array of the values from the host layout.
2026-06-10 11:39 AM
Yep, exactly. That's the GLOB_ISSUE_SCHEME global.
To cite the ref man:
Available in all context. 2-row string array, containing the names of fields defined in the Issue Scheme (first row), with the corresponding GUIDs (second row). The first five columns are fixed: Revision ID, Issue ID, Issue Name, Issue Date, Issued by.
