Wednesday - last edited Wednesday
An author of a GDL object might want to sell it while also preventing buyers from sharing it with others. How is it done?
A GDL object cannot make HTTP requests and, to my knowledge, does not have access to any crypto libraries.
I have some ideas, but there may exist simpler solutions already:
The GDL author creates a C++ Add-On and sets up a license server. The sole purpose of the Add-On is to communicate with the license server, since the GDL object itself cannot make HTTP requests.
The flow:
ACAPI_Notify_CatchNewElement.The Add-On queries the license server using:
The server responds with a signed license (for example containing expiry date etc.). The important part is that the license is signed with the license server’s private key (for example using RSA).
Since a GDL object can be password protected, a user would not be able to simply remove the license check from the script itself. And you cannot easily edit the GDL code outside of ArchiCAD either.
The problem is step 4.
How would you realistically verify RSA signatures inside a GDL object? It does not seem very feasible to implement RSA verification manually in GDL.
The simpler alternative would be to let the C++ Add-On perform the license validation and then simply write an is_valid parameter into the GDL object. However, that seems insecure because someone could create a fake Add-On that just writes is_valid = true without checking any license.
Solved! Go to Solution.
Thursday - last edited Thursday
https://community.graphisoft.com/t5/GDL/Cloud-Licensing-and-GDL/m-p/589158#M6356
You can request the UserID & OrganisationID so you can just hardcode in a check value against one of those. I think Ben's library has a seperate licencing object which all of the others reference that contains this check as well as an expiry date.
Ling.
Wednesday
TBH, I've never made enough $ from selling my objects to care much about who's sharing them. In fact, when a firm pays me to build a custom template, I often just load the embeded library with a bunch of the more useful objects.
I think you'd need to get into an add-on/plug-in that ties to a given GS license/GSID... similar to cadimage. Maybe buy a c/i seat and reverse engineer how they did it?
Ling.
yesterday - last edited yesterday
Thanks for the link, that looks like a good and simple solution. If i understand it when a user makes a purchase you encode that user id into the GDL object? I wonder if it is possible to automate.
And if you want a recurring subscription model using only a GDL object the user would have to manually renew it after expiry date?
Thanks for the tip, at least if you want automated recurring subscription model you probably need an Add-On to make web requests to a license server.
And I'm not 100% sure but I think GDL datetime uses the system clock which can be changed by the user. If that is the case then using it for expiry checking might not be suitable.
