Tuesday
I am getting "Archicad 27” is damaged and can’t be opened. You should move it to the Trash" after installing the 27.2.2 Hotfix. What should I do to remedy this seemingly dire situation? Intuition tells me to reload the the original install and apply the Hotfix again. The only help the internet has provided for a solution less than that, seems a be questionable. Thanks
Operating system used: Mac Apple Silicon 14 Sonoma
Solved! Go to Solution.
yesterday
This happened to me and the only solution was to "uninstall" and reinstall.
another Moderator
yesterday
another Moderator
yesterday
Yep. Decided to go that route shortly after posting. I actually wasn’t as painful as I was expecting. Took care of the problem in short order. Thanks for responding though!
