2024-11-13 01:57 PM - last edited on 2024-11-19 05:33 PM by Laszlo Nagy
In Archicad 28 version 3060, the function to temporarily toggle Quick Select with the spacebar is not working, while using Shift + Spacebar does work. Is there a way to adjust the settings to fix this?
PS 1.
I've already tried resetting the settings.
PS 2.
Rolling back to version 3000 restored normal functionality.
Operating system used: Mac Apple Silicon 15.1(24B83)
Solved! Go to Solution.
2024-11-14 10:05 PM
As someone who thinks ALL CAPS is a blight on our profession (all caps notes are harder to read, cause confusion with abbreviations, etc. etc. etc.) I hate that this is a functional workaround with a fiery passion.
2024-11-15 01:48 AM
Just redownloaded Archicad 28 and repaired my installation back to 28.0.0 (3001). Spacebar works again and I didn't have to reinstall my Work Environment. Much better.
2024-11-15 01:54 AM
I have reported this as a bug.
Hopefully it will be fixed sooner rather than later.
Maybe if everyone affected also reports it to their local support, it might get more attention.
2024-11-15 04:47 AM
That's funny!
2024-11-15 11:27 AM
I've reported it too and the update has now been pulled from the downloads site.
2024-11-15 11:34 AM
Hello there,
I updated the Insights post about the Archicad 28.0.1 Hotfix release where this issue is addressed in detail.
UPDATED: Archicad 28.0.1 Hotfix release - Graphisoft Community
But to reflect on your questions directly:
- the easiest way to revert to the previous version is to perform a "Repair & Install" of the main release version of Archicad 28 (build 3001).
- we are currently working on fixing this defect, and intend to include the bugfix in the upcoming AC28.0.2 Hotfix, which is expected to be available in a couple of weeks.
Apologies for the inconvenience and thank you for your understanding!
Kornél
Beleznai Kornél
Technical Support Engineer
2024-11-15 03:32 PM
Hi Kornel, first of all: thanks for acknowledging and communicating here! Good job.
Also thanks for taking the update down, that was the right and only choice.
However I am a bit disappointed by the time frame: "A couple of weeks"? That means new year in my book since the year is basically over.... 🤨
On the bright side:
At least the Install repair works fine – whoever else installed it: You can roll it back and everything works!
...buuuut it still takes time. I'm just so glad that for once I didn't roll out the update for all my coworkers but used it myself first. I just wish QC would catch those obvious kind of problems.
2024-11-15 04:34 PM
Does the install repair retain the work environment and other settings or does it revert back to a fresh install?
2024-11-15 04:58 PM
Oh yeah, sorry Lee, should have answered that already in the other post:
YES, IT DOES PRESERVE!
Even tho there is a scary message in the beginning which says otherwise (maybe the German translation is just badly worded). But no, I had no issues, I could jump directly at my files, the list was still populated btw, my add-ons are still installed. All good.
2024-11-15 05:01 PM
I resolved the issue by downloading the 3001 version installation file and overwriting it. All settings remain intact, and only the problem is resolved.
