Fixed width/height windows and doors
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2015-05-19
05:18 PM
ā2023-05-24
12:32 PM
Rubia Torres
I wish to have a special library folder with a limited number of windows we use in a project to avoid having same ID windows with different parameters. That would make scheduling much easier.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2015-06-12 04:09 PM
Also, you didn't address the User Interface question. How would you solve that? How much work that would be?
I mean, you are welcome to try but I don't think it will be an easy and simple task if you want to control all Windows in the default ARCHICAD library from one "master" Window object.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2015-06-12 05:01 PM
I simply call the window with some fixed arguments.
As soon i've finished my little lamp (coding lights is a pain) i will try to code what i'm unable to explain ok?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2015-06-12 06:48 PM
You will only have a huge parameter list and you will have to figure out which parameter does what and you will not have the help of icons and explanation graphics.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-08-09 09:13 AM
Best,
Peter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-08-10 04:03 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-08-10 05:41 PM
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-08-11 12:30 AM
if you use that as the base for all the parameters and then call the suitable W2, W1 etc. window then you get a universal library part.
i did this for a building company a few years ago, and they had 1 window library part with sliding, awning, double pane, single pane, basically everything. (they had over 500 windows to choose from, from their supplier)
there were 3 windows that the archicad tools could not produce, they were matrix windows with opening panes, and i just added some special condition code to draw opening sashes for those special conditions when that combination was chosen.
it can be done if you have a month to spare and know every window that you can choose from. once everything was in an excel spreadsheet it took less than a week to code the library part. getting all the correct frame sizes, changes in mullion widths(and slight changes to overall windows) for the chunkier frames, etc was the hard bit.
the tree below shows a map of calls from the standard archicad windows.
P.S.
if you call the window out of the master script, then you still have the standard archicad window user interface available for all the other settings.
you just have to remember to lock the fields that you don't want changed for that window.
remeber to call the window, not the macro i.e.
if a < 1.2 then
call "Window 18" parameters all
endif
if a > 1.2 and a < 2.4 then
call "Double Window 18" parameters all
endif
if a > 2.4 then
call "Triple Window 18" parameters all
endif
from AC 19 a sub library macro (GS Corner Window Functions) has Hideparameter all in the parameters script, so you will want to change that so it doesn't hide your parameters, or you will need to be able to add your drop downs into the GUI.
i.e. add the parameters you still want visable after the all command.
hideparameter all "My_Window_Style", "My_Window_Opeing_Type", "My_Window_Sizes"
both require a library hack.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2017-09-25 05:24 AM
I've been trying to implement this script into default AC 20 window, but the parameter doesn't show up in Window Selection Settings. The script test turns to be ok and the Width and Height are grayed out like in your case, but the drop-down menu is not visible. Do you know what may be the reason for that and or where can I find this drop-down menu?
Additionally, is it possible to force showing "All Parameters" in the drop-down menu from attached file?
Thanks
- Ā« Previous
- 1
- 2
- Next Ā»
- Ā« Previous
- 1
- 2
- Next Ā»
