2019-03-31
05:31 PM
2023-05-24
08:13 AM
Rubia Torres
Solved! Go to Solution.
2019-04-16 09:25 PM
Erwin wrote:If I didn’t have clients who want to see finishing I also wouldn’t include trimming or floor finishes. I build a model for two reasons; one to show my client what they’re buying and the other to generate construction documents.
We don't even model the plaster on the walls. I'm just a simple bachelor degree engineer though, so certainly not a real architect by our national standards![]()
I want the shell of the building in my drawings, that's what I need for dimensions for the contractor. Trim and finishes are in the 2D detail drawings.
2019-04-18 08:51 AM
Michael wrote:Sadly for our ussual well to do clients with large (1000-2000 m³) homes it seems 'required' to get an interior 'architect'. So most of the time we are stuck with not designing the interior (and thus not creating renders of this).
2020-05-22 06:38 AM
2020-05-22 10:26 AM
2020-05-22 12:48 PM
Braza wrote:Thanks. Turned them on, but moving opening ref lines between baseboard and wall face did nothing. Baseboard still tucked in behind casing as pictured in the previous post.
On the Profile Editor, Check for: Design Layers > Opening Reference, and turn it on. Then place these reference lines between the baseboard and the wall face.
Hope that helps.
2020-05-22 07:42 PM
2020-05-22 11:45 PM
2020-05-23 02:42 AM
Braza wrote:Thanks. Setting to custom or frame= wall thickness makes no difference either.
Ok. Then I'd check frame width inside door settings. It must my set to "Custom" instead of "Fit Wall thickness".
That is what come to my mind for now.
2020-05-23 01:15 PM
2020-05-23 03:00 PM
