Column segment horizontal offset?
Geof Gainer
Can a column segment be horizontally offset from the other segments? Eg. a wood post eccentrically placed on its concrete base.
AC fan since v 7. Currently on AC 28.1.1 (4100) USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Sequoia 15.5
The only way I think it can be done is to use a complex profile for the segment.
You can the adjust the origin point of the complex profile to adjust the position of that segment.
runxel
Hero
https://archicad-talk.graphisoft.com/viewtopic.php?f=25&t=69631
POSIWID – The Purpose Of a System Is What It Does /// Ā«Furthermore, I consider that Carth... yearly releases must be destroyedĀ»
