‎2015-02-02
09:00 PM
‎2023-05-24
08:53 AM
Rubia Torres
‎2015-02-04 11:38 PM
Richard wrote:rob2218 wrote:Certainly possible, but takes time to set up and then manage pens very carefully. I always seem to make a few mistakes. I think it's just faster to have a "Walls Only" view, where you can just take a view and change all the pens to gray. And another view of "Electrical Only" where you can change all the pens to black.
Background for electrical information?
huh? wouldn't you just use an "electrical" penset that makes the electrical objects 'bolder'?
‎2015-02-06 11:20 AM
rob2218 wrote:You don't need model view options to make the background in a section view different than it is on the floor plan.
humm...bummer.
well, what I've had to resort to...which defeats the whole "BIM" purpose is add a cover fill type hatch over in the areas that are "concrete".
Due to the architects rather unique criteria for how drawings should look, this is what I had to do.
here's what it looks like. Wish I could get the same results simply with a MVO adjustment.
‎2015-02-06 11:37 AM
‎2015-02-06 06:14 PM
Steve wrote:rob2218 wrote:You don't need model view options to make the background in a section view different than it is on the floor plan.
humm...bummer.
In Building Materials, you can set both the pens the the same.
Then use the section settings to change the background so the pattern show up do to the contrast. It will not show in plan view.
Is that what your wanting to do?
‎2015-02-06 09:25 PM
‎2015-02-06 09:37 PM
‎2015-02-06 11:29 PM
