Flat slab with sloping top surface
KeesW
Gurus
Is there an easy way to draw a concrete floor slab with a flat underside but sloping top? One often has to construct slabs for outside decks that incorporate a slight falls for drainage. It is not the same as drawing a ramp because these have sloping undersides and tops.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
11 REPLIES 11
Mesh?
KeesW
Thanks Stuart. I know about meshes. However, using a slab and shaping it in-situ is probably more flexible. However, I'll use the mesh method if necessary.
NCornia
Graphisoft Alumni
Graphisoft Alumni
Perhaps this wiki article by AC wizard Laszlo Nagy has something that may help: http://www.archicadwiki.com/FlatTopRoof
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
KeesW
Thank you Nicholas. I'll do it as suggested.
TMA_80
I really would like to have this options in ArchiCAD without workarounds as we could in...Revit ...
AC12_27 |Win11_64bit|
NCornia
Graphisoft Alumni
Graphisoft Alumni
Enter the Shell tool in AC 15. It can be classified as a slab. Will show up in plan, 3D, elevation/section correctly. No SEO or workarounds needed.
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
TMA_80
That is good to know...
But let me add that the source and basic info on which this article (and many others) is based was posted here on ArchiCAD-Talk by various members.
I only put together an article based on info found here.
custom profile
