Flat slab with sloping top surface
KeesW
Gurus
Is there an easy way to draw a concrete floor slab with a flat underside but sloping top? One often has to construct slabs for outside decks that incorporate a slight falls for drainage. It is not the same as drawing a ramp because these have sloping undersides and tops.
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
11 REPLIES 11
Mesh?
KeesW
Thanks Stuart. I know about meshes. However, using a slab and shaping it in-situ is probably more flexible. However, I'll use the mesh method if necessary.
NCornia
Graphisoft Alumni
Perhaps this wiki article by AC wizard Laszlo Nagy has something that may help: http://www.archicadwiki.com/FlatTopRoof
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
KeesW
Thank you Nicholas. I'll do it as suggested.
TMA_80
I really would like to have this options in ArchiCAD without workarounds as we could in...Revit ...
AC12_27 |Win11_64bit|
NCornia
Graphisoft Alumni
Enter the Shell tool in AC 15. It can be classified as a slab. Will show up in plan, 3D, elevation/section correctly. No SEO or workarounds needed.
Nicholas Cornia
ARCHICAD on Twitter
Tutorials
TMA_80
That is good to know...
But let me add that the source and basic info on which this article (and many others) is based was posted here on ArchiCAD-Talk by various members.
I only put together an article based on info found here.
custom profile
