How to create walls with lower half rick veneer?
4hotshoes
I have a house with full height brick veneer and walls where the brick extends up only 36" with a stone cap and the rest of the wall has siding above. Then I have a window that cuts into both the brick and the siding. What is a good way to create and manage that? What options are there for creating the wall with a window?
Thanks,
Todd
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
5 REPLIES 5
All pretty easy to do using complex profiles. If you haven't used profiles before, this video may be a good introduction, even though it is for a commercial project:
https://youtu.be/2gCY7vODRjU
See also:
https://helpcenter.graphisoft.com/guides/archicad-21/archicad-21-reference-guide/user-interface-refe...
One of the forum moderators
AC 28 USA and earlier   •   macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Dontknow
I've got this video of a composite wall made in the profile manager, with on the outside two different materials.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Can you post the video in a universal video format? WMV files are pretty much only Windows ... or require an obsolete 3rd party add-on for Macs. (Original poster is on a Mac.)
Dontknow
MP4?
ArchiCAD 25.
Thanks,
Todd
Model the wainscot and stone cap as seperate walls. Make the one under the window shorter or perhaps use an empty opening in that wall where you have the window in the other wall.
Something like this?
