2023-08-31 05:30 PM
If you change the home story on the wall, the top link also changes.
So we need to change the Top link again.
I would like to know how to make only the home story change.
Should I increase this feature of the Fat Palette alone?
Solved! Go to Solution.
2023-08-31 07:26 PM
relink home story will pull top linking if it conflicts with the initial geometry. Changing home story in the wall settings will not; it will mess with the wall geometry and position. Maybe this helps explain it a bit better?:
(uploaded vid may not be complete at the time of posting this)
https://youtu.be/tlfST8szx3g
2023-08-31 05:59 PM
right click > relink home story. position and geometry should remain as-is, but home story association is updated.
2023-08-31 06:27 PM
thank you
This is the answer from the last question.
Solved: Re: I would like to change only the standard story... - Graphisoft Community
My question is how to keep TOP LINK from changing even if I change HOME STORY.
2023-08-31 07:26 PM
2023-09-01 02:56 AM
That is the whole idea of the top/bottom link.
When you change a storey height, the walls will follow.
If you don't want the walls to change, don't link the top/bottom to the storey.
2023-09-01 03:38 AM - last edited on 2023-09-01 03:50 AM by Barry Kelly
I would like to read an explanation of the check marks and targets in the Pet Pallete Tracker Home Story.
Where can I read the manual?
2023-09-01 04:15 AM - edited 2023-09-01 04:16 AM
The check mark is simply another way to accept the value - same as OK or Enter.
The target is a way to mark the position with blue snap guide lines.
So instead of actually stretching to that position, it will simply add snap guide lines at that point.
You will notice that easier stretching a length in plan.
In the manual I didn't see it mentioned in the tracker explanation, but in the snap guides I found this.
2023-09-01 06:32 AM
Today again, I see hope in you. ^^
I'm not good at using guide lines and trackers because I learned by myself using text.
If there are any courses you can recommend on YouTube, etc., could you please recommend them?
Today again, I look at you with gratitude. ^^
2023-09-03 07:16 AM
There are often cases where the top link keeps becoming not linked.
Are there any other options?
