2026-01-11 12:13 AM
I think I know the answer to this, but wanted to check and be sure.
I have a composite roof meeting a composite wall, and I want the plywood and roofing skins of the roof composite to extend past the wall to create an overhang (which will be supported by a custom profile rafter tail object). Is it possible for some of the skins of the composite roof to extend a couple of feet beyond the edge of the framing skin of the roof?
I think I have to model the framing of the roof and the sheathing/finish as separate roofs in order to get that overhang that I want, but wanted to see if I'm missing something here.
(For the record, if I do the 2-roof workaround, my wall composite skins won't be cut by the shorter roof structure, so I have to model the wall as two separate walls as well!)
Here's a sloppy version trying it with a structural wall and a finish wall, and a structural roof and finish roof. You can see how I want the roof sheathing skins to extend past the roof framing skin. I don't have it all resolved and joining correctly here, but I can get it to work. But you can imagine it becomes very unwieldy trying to edit and to deal with doors and windows when everything is a "double" wall or "double" roof! There must be a simpler way???
Tuesday
Hello @jd10003 ,
Did you try this ?
https://www.youtube.com/watch?time_continue=121&v=sKAlxxFp8Lo&feature=emb_logo&ab_channel=GoStobbart
Tuesday
I use a combination of solid element operations and merge. I know the trim to roof is supposed to be cleaner, but it's glitchy over time.
Tuesday
for the roof overhang, it's a combination of a separate roof, and complex profile beams.
21 hours ago
I gave up and hit it with some 2D graphic workarounds. Will try again when I have more time.
19 hours ago
I would model the top continuous skins as the main roof.
This would be in the roof layer that you will se in plan and elevations.
And then model a separate roof for the inside framing part that stops at the wall.
This will be in a ceiling layer that you only see in sections and 3D model.
