Measuring problems in Teamwork
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-09-01
12:13 AM
2023-05-26
03:13 PM
Rubia Torres
However, I'm in a teamwork file and someone else is working on the plans and I'm on the elevations. How do I measure the size and location of a window if I can't use the line tool to measure with (i.e. I'm locked out of the plan space)? A measure tool would really be useful right about now.
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-01 09:18 PM
Bruce wrote:I'm not sure I understand what you're asking... why would you use the Window Tool for this?
What's wrong with a measuring tool? We wouldn't be having this discussion if there was a measuring tool![]()
Hypothetical: Two walls meet at an acute angle in a workspace that isn't reserved for you. How do you measure perpendicular to the wall that doesn't run in either the x or y axes? Opening the window tool to read the distance doesn't work because you're after the positioning, not the size.
Wouldn't just rotating your working grid allow you to get distances along any angle?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-01 09:33 PM
I've attached a screenshot of what I mean. And no, adjusting the coord angle has no effect if you're using the method described by Link below - well not in this example anyway.
I would use the window tool because that's what Djordje suggested below.
I didn't realise it would be that significant a problem to provide a basic, requested tool like a tape measure. It's like telling a builder he doesn't need one - just put marks on the back of your saw, or use your straight edge. Who needs a tape measure?
Mindmeister Mindmap
-- since v8.1 --
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-01 10:27 PM
click on node at right
select perpendicular constraint
click on wall at left
hover over wall to get perpendicular cursor
read off 'r' value
bill
a dedicated measuring tool would probably work identically
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-01 10:38 PM
I'm sure someone will offer another obscure 'solution', but that misses my point entirely. Why isn't the obvious, simplest solution available?
Mindmeister Mindmap
-- since v8.1 --
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-01 10:43 PM
Obscure enough?
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-01 10:44 PM
And no, adjusting the coord angle has no effect if you're using the method described by Link below - well not in this example anyway.I just tried it, and it works perfectly.
Adjust your angle to match the angle of the wall you want distance perpendicular to. Place the reference point on the end of the wall, as you show in the screen shot, then hover your cursor over the other wall.
The Y value will be the perpendicular distance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-01 10:47 PM
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-01 10:47 PM
Bruce wrote:You asked a question. Link and I answered it. (though it took a few rounds to understand the problem). It's not an obvious solution. As far as I know, it's not in the manual or in any of the Help. But it works, and it's pretty simple to learn.
It works in all projects, teamworked or not, and does not require the extra "escape" at the end of an uncompleted drawing command, making it more efficient than the current process a lot of people use.
While your frustrations are understandable, they should not be directed at those of us trying to help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-01 11:06 PM
if what i described doesn't work i'd be pretty annoyed too
bill
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-09-01 11:18 PM
Djordje wrote:What Window width? I'm not sure what you mean by that.Rob wrote:Any linear tool will do ... wall, beam, polyline.
well, the problem is when you want to measure a perpendicular distance to the target for example (the most common measurement that we do on plans, I recon) and you're scr..ed mate. so may be we should have some tool for measurements (??)
Or, click on the line that represents the window width and open Object info. It will tell you the lenght.
