ā2005-09-01
12:13 AM
ā2023-05-26
03:13 PM
Rubia Torres
ā2005-09-01 09:18 PM
Bruce wrote:I'm not sure I understand what you're asking... why would you use the Window Tool for this?
What's wrong with a measuring tool? We wouldn't be having this discussion if there was a measuring tool![]()
Hypothetical: Two walls meet at an acute angle in a workspace that isn't reserved for you. How do you measure perpendicular to the wall that doesn't run in either the x or y axes? Opening the window tool to read the distance doesn't work because you're after the positioning, not the size.
ā2005-09-01 09:33 PM
ā2005-09-01 10:27 PM
ā2005-09-01 10:38 PM
ā2005-09-01 10:43 PM
ā2005-09-01 10:44 PM
And no, adjusting the coord angle has no effect if you're using the method described by Link below - well not in this example anyway.I just tried it, and it works perfectly.
ā2005-09-01 10:47 PM
Bruce wrote:You asked a question. Link and I answered it. (though it took a few rounds to understand the problem). It's not an obvious solution. As far as I know, it's not in the manual or in any of the Help. But it works, and it's pretty simple to learn.
I'm sure someone will offer another obscure 'solution', but that misses my point entirely. Why isn't the obvious, simplest solution available?
ā2005-09-01 11:06 PM
ā2005-09-01 11:18 PM
Djordje wrote:What Window width? I'm not sure what you mean by that.Rob wrote:Any linear tool will do ... wall, beam, polyline.
well, the problem is when you want to measure a perpendicular distance to the target for example (the most common measurement that we do on plans, I recon) and you're scr..ed mate. so may be we should have some tool for measurements (??)
Or, click on the line that represents the window width and open Object info. It will tell you the lenght.
