2012-07-27
12:25 PM
- last edited on
2023-05-24
07:31 PM
by
Rubia Torres
2012-07-27 04:39 PM
2012-07-30 10:07 AM
2012-07-30 10:08 AM
2012-07-30 10:13 AM
2012-07-30 12:02 PM
2012-07-30 12:10 PM
Gorazd wrote:I'm in the same sitution... I modelled all this things to practice with morph, and each piece took me less time too. If you know how to modell with c4d, morph is very easy, limited of course but very easy.
Thank you. Theese foldable chairs are iconic in Slovenia and are sold throughout Europe since sixties. Modeling them was my way to learn the morph tool, each piece I made took me less time.
2012-08-03 02:33 AM
Jose wrote:I am new to Morph and still finding it virtually unusable. My biggest problem is how to RELEASE the mouse from making something. Every attempt to do so results in the object getting larger and larger and larger. does one hit ESC, does one hit Enter, does one double click, or does one right-click and select OK? None of these seem to work.Gorazd wrote:I'm in the same sitution... I modelled all this things to practice with morph, and each piece took me less time too. If you know how to modell with c4d, morph is very easy, limited of course but very easy.
2012-08-06 07:42 PM
david wrote:Its very tricky at first but with some practice you can do almost anything. If you need more precision you can deactivate the "3d sensitive cursor" in the process and when you finish activate again....
The most valuable key combination is Ctrl-Z, because even if you have made an effort to form a shape, you think its done, move the mouse away and suddenly the object goes crazy.
2012-08-07 03:21 PM
Jose wrote:I looked around a bit, help etc, could not find "3d sensitive cursor", a hint maybe?
..... If you need more precision you can deactivate the "3d sensitive cursor" in the process and when you finish activate again....
