Text tab settings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-05-28
04:53 AM
‎2023-05-26
02:09 PM
Rubia Torres
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-28 05:36 AM
They can also be adjusted by dragging them along the ruler or removed by dragging them off the ruler.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-28 05:46 AM
It seems a little buggy to me as sometimes you can create a new tab between existing tabs and sometimes it just moves the next tab along.
The tabs also seem to be set line by line - not for the entire paragraph when you are adjusting them.
Although once you have the first line set up and then 'Enter' for a new line it will use the tabs of the line above (but still they adjust separately).
Beaten to the punch by Matt.
I hadn't tried selecting all to adjust all lines at once.
Mind you I had never tried to adjust the tabs before either.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-28 06:28 AM
I must have tried it once with a corrupted file and it didn't work. So, I didn't try it again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-28 05:24 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-06-15 11:12 AM
Reviving this thread... Is there a way to change the tab type? I am wanting centre tabs after the initial indent.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-06-15 11:39 AM
After the initial 'custom' tab on any line, it will revert back to 'standard' tabs (what ever spacing that is - 1.25 and a little bit units - text size seems to have no impact on this spacing).
If you look just under the ruler, you will see very small faint marks where the standard tabs are.
Every time you create a custom tab position, the standard tabs before it are wiped out but you will see them after it.
I hope that helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-06-16 04:03 AM
In the Microsoft and Adobe Suites, as well as AutoCAD:
Header - Hanging - Left - Middle - Decimal - Right
Is this possible in AC? Given how AC is with all other text formatting...
Ling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2022-06-16 04:15 AM
It seems not.
Just regular left justified tabs only.
No option to change them to other types of tabs.
