2024-05-24 04:28 PM
This issue is driving me crazy and I don't know if there is even a solution to it.
What I am trying to do: Say you have your GIS 2D map with all your roads, grasslands, water and other features and everything is neatly combined in groups. I want to make meshes/slabs out of them and then with solid element operations to substract/add them from a terrain mesh. This requires ofc to turn all these elements into something solid first.
Problem is, you can't turn them into a solid all at once but you have to select them one by one. Even worse, if the element is making a loop (say, a road that encircles a grass field), then the selection will create an area including the inner one, resultling in having to substract the inner area afterwards
All this is incredebly time consuming and I am trying to find a workflow of making urban contexts in archicad easy.
2024-05-26 01:00 PM
This would be very easy to do with the Archicad-Grasshopper Connection.
Using a Grasshopper command, you can select a group of elements in Archicad and use them as source. Then, based on their geometry, you could generate those Meshes/Slabs from Grasshopper.
Might be worth taking a look at that workflow.
2024-06-03 03:26 PM
Hi Laszlo,
Unfortunatelly Rhino is not an option but yeah that would be sweet.
It would be nice if Graphisoft gave a comprehensive guide on how to make contexts easy based on actual 2D/3D urban situations because I really can't find a cohesive one so far and without 3rd party paid plugins
2024-06-05
12:28 PM
2024-06-06
05:18 PM
To help you can use the Profiler Add-On witch is in the Goodies suite.
Select a group of Fills, Extrude them with the Add-On will create a 3D object on plan but oriented horizontally.
You can then convert this object to Form and Rotate and Move it to the right position.
