2016-08-20
07:25 PM
2023-05-24
08:37 AM
Rubia Torres
2016-08-24 12:28 AM
NCornia wrote:Perfect!
Hi Richard,
In the Work Environment there is a setting to control how far the cursor must be from an element to snap to it. The default cursor snap range is 5 pixels. On newer high resolution displays 5 pixels can equate to a very small portion of the screen. You might try increasing the number to see if it makes a difference in your experience with the cursor snapping to the guide lines.
Options > Work Environment > Input Constraints and Guides
Best regards,
Nick
another Moderator
2016-08-24 12:42 AM
2016-08-25 04:52 PM
2016-08-26 11:21 AM
2016-09-03 02:40 PM
2016-09-03 05:39 PM
laszlonagy wrote:The SHIFT key no longer constrains to ABSOLUTE vertical/horizontal/45 deg. It now constrains to those -- but RELATIVE to whatever snap guide is closest. So if you have a snap guide that is slightly off, you will get new items created that are slightly off, also.
I don't know, Snap Guides or no Snap Guides, I always press the SHIFT button to make sure I am drawing horizontal and vertical lines. Maybe it is something that stayed with me from using ARCHICAD for 20 years.
2016-09-05 10:39 AM
2016-09-05 04:54 PM
2016-09-05 05:56 PM
Erwin wrote:I think you can. There's an icon and you can also assign a shortcut key.
Part of the problem is the snapguides that create circles, extra connecting lines etc etc. The other day I was tracing a complicated polygon-shape and the amount of feedback you end up with on the screen is horrible, you can't turn them off either if you want a simple midpoint snap.
2016-09-05 07:00 PM
Richard wrote:If you have one snap guide active while drawing complex shapes and getting a lot of feedback, you can hit ESC and it'll make them disappear without canceling the drawing operation. Just be careful not to do it if you don't have any snap guides or you'll cancel everything and actually cryErwin wrote:I think you can. There's an icon and you can also assign a shortcut key.
