2013-10-12
02:23 PM
2023-05-24
12:45 PM
Rubia Torres
2013-10-12 03:02 PM
2013-10-14 12:08 PM
2013-10-14 12:29 PM
KeesW wrote:Check if there aren't elements on other layers in the same place as this stud Wall with a higher priority. Also, select the Column and Wall then open the Building Materials (sort by selection column) - and post a screenshot. That might help us.
I've checked intersection priorities and steel for columns is 800 while timber studs are 500. When I move the column it clearly shows the wall obscuring the higher rated column. Obviously, the problem is not priorities - but what is it?
2013-10-14 10:57 PM
