2023-05-26 06:21 AM - last edited on 2023-06-06 10:43 PM by Laszlo Nagy
Help please!!
I'm creating a new template from scratch and new composites. When creating it, I made sure to mark that it could be used as a composite for walls.
However, when drawing the wall, I cannot see my newly created composite; it's just red.
I attach the images. Any idea what's wrong?
Solved! Go to Solution.
2023-05-26 06:38 AM
Check your Renovation Filter? For some reason Renovation Status can be set when the filter is turned off...
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2023-05-26 07:17 AM
Set a renovation filter that does not override anything.
2023-05-26 06:38 AM
2023-05-26 07:11 AM
Thank youu!! In some way, I fixed it with your answer. If i put the wall in existing it apears de composite, but if i put in demolition or new it changes again. How can I make the composites look in the other renovation status?
I really thank you for your help.
2023-05-26 07:17 AM
2023-05-26 07:26 AM
Thanks to you both! I solved my problem.
