Jennyfer_0605
Beginner
composite wall not showing
Help please!!
I'm creating a new template from scratch and new composites. When creating it, I made sure to mark that it could be used as a composite for walls.
However, when drawing the wall, I cannot see my newly created composite; it's just red.
I attach the images. Any idea what's wrong?
2 Solutions
Lingwisyer
Guru
Check your Renovation Filter? For some reason Renovation Status can be set when the filter is turned off...
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
Go to post
Set a renovation filter that does not override anything.
Go to post
4 Replies 4
Lingwisyer
Guru
Jennyfer_0605
Beginner
Thank youu!! In some way, I fixed it with your answer. If i put the wall in existing it apears de composite, but if i put in demolition or new it changes again. How can I make the composites look in the other renovation status?
I really thank you for your help.
Jennyfer_0605
Beginner
Thanks to you both! I solved my problem.
