multi split level buildings
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-01-17
09:18 AM
‎2023-05-24
12:43 PM
Rubia Torres
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-17 03:55 PM
https://www.youtube.com/watch?v=osEAOJgDPPU
Sterkte
ArchiCAD 25.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-01-30 08:51 AM
AC26, iMac
User since V5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-02-02 12:48 AM
the video looks useful - if only I could understand it!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-02-02 12:50 AM
How do you set levels and stories when splits are staggered @ 1350mm?
Could you please expand your answer?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-02-02 08:59 AM
Draw you model with all the elements at the correct z value to create your split level all within the ground floor storey.
Create a normal view for the ground floor using a conventional cut-plane of say 1100.
Then create another view for the upper ground floor with a cut-plane of say 2450 (1350+1100). That cuts the doors and windows correctly for the upper ground floor.
Place both views onto a layout and knit them together along the line of the level change. What you then see is a single ground floor plan showing both levels correctly.
AC26, iMac
User since V5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-02-02 11:25 AM
So you don't use stories? Instead, you create everything on the Ground Floor and then separate them into required stories with cut lines. Each separated 'storey' is then saved in its own Navigator view map. Have I got that right?
I had hoped that 'All relevant stories' would do that.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-02-02 11:57 AM
There tends to be a certain amount of masking of unwanted elements etc with the small story differences, but it is possible to make it work.
Also keep in mind the behaviour of things like stairs with story up and story down symbol. Doors and windows are also notoriously fiddly with 2d symbols.
Things like wall projection play a huge part in getting the floorplan to look like you would want.
Sometimes you have to divide walls up vertically per story to get the sort of behaviour you would like in floor plans.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-02-02 12:02 PM
www.leloup.nl
Windows 10 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-02-02 11:49 PM
Maybe 2D CAD is not dead after all.
