2024-01-11 02:21 AM - last edited on 2024-01-14 11:25 PM by Laszlo Nagy
Hi all,
I wanted to bump this topic: https://community.graphisoft.com/t5/Project-data-BIM/Multiple-entries-for-the-same-beam-profile/td-p... but it appears locked so I can't reply over there.
I am having the exact same issue, (AC27 4030): essentially all of my Complex Profile elements are being scheduled twice. I am trying to create an A1-A3 carbon emissions schedule so cannot have the scheduler double-counting elements - it inflates my carbon footprint! 'Merge Items' does not work: it hides the duplicates but still schedules twice the amount that I have in reality.
Before you ask: I have double checked, triple checked and more: I absolutely do not have duplicate elements in the model. Interestingly, if I assign a unique ID to each element, this ID is NOT assigned to the ghost duplicate (see attached screenshot). If I use the scheduler's selection tool to select in 3D and delete ONE of the ghost elements it deletes both entries...
Clearly quite a critical bug and I am surprised this is still hanging around from the original post back in 2021. Any advice or input from others experiencing similar?
~/BF
Solved! Go to Solution.
2024-01-11 08:27 AM
Can you show your schedule criteria?
I am wondering if it has something to do with the beam / beam segment both being scheduled.
You really only want one or the other.
2024-01-11 08:27 AM
2024-01-11 08:04 PM
Thanks - that was exactly it. I heard back from GS overnight with the same. Quick question - before I dive in to investigating myself - would this be the same for all assembly-type elements that have their own sub-elements, i.e. Stairs, Railings and Curtain Walls?
I don't actually understand the logic of this. I get why being able to schedule sub-elements could be important, but surely scheduling the parent element should automatically exclude its own sub-elements so as not to double count by accident? Hungarian logic?
Thanks again,
~/BF
2024-01-12 09:13 AM
Despite it's another question which should be in different post but here is the answer for it.
2024-04-04 11:29 AM
That tip has quite a cumbersome workaround. You can simply filter out the "Beam Segment" and "Column Segment" and similar using the Element Type as a filter in your schedule criteria.
2024-04-04 10:55 PM - edited 2024-04-04 10:56 PM
That is exactly what I ended up doing Stefan. I still have the 'how-can-this-possibly-be-what-I-want' reaction. It should never double count by default, only if it's told to...
~/BF
