Visualization
Cineware renderer quits in ArchiCAD 28
svpribyl
I just downloaded and installed ArchiCAD 28 and I get the same message regarding Cineware rendering engine quitting that I got with the 28 Technology preview:
Operating system used: Mac Intel-based
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
38 REPLIES 38
Can you please tell me where the new link for the download of the Cineware folder is?
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
In the article that Karel linked to ...
But I will add it here to save finding it.
https://graphisoft.sharefile.com/share/view/s0047a28b64a742b8930f768c6faf2a98
this link is not working anymore but it has solved the problem for me last time. Could you please re-upload the file?
@MatejVacek
See this post later in this thread ...
https://community.graphisoft.com/t5/Visualization/Cineware-renderer-quits-in-ArchiCAD-28/m-p/667667/...
Try the links there.
alemanda
A friend of mine had the same issue on ac28 student version Mac intel based under sequoia OS and, after contacting graphisoft, they provided the solution suggesting to delete the plugins folder under Cineware folder.
Problem solved.
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Hi Karel,
I still have this problem, have reported it to Graphisoft tech support, and they are unable to provide a solution.  The link for a new cineware folder does not solve the problem, nor does deleting the plugins folder. I have tried v 27, 28, and 29, as well as downgrading my macOS to Sonoma on a separate partition. No luck with any of these solutions.  Running Mc OS 15.6.1 on a 2019 Macbook Pro.  I was able to render for years until just earlier this year, possibly when I upgraded to Sequoia, so I assumed downgrading would solve the problem, but that was not the case. Any help would be much appreciated. Thanks
the original solution (replacing the folder) was reccomended via Graphisoft.
Unfortunately I'm not aware of any other workarounds. You have to keep sending data to Grahpisoft and probalby based on fastloggers they could help you.
From Archicad 17
MacBook Pro M1 Max
If you delete the 'Redshift' folder from within the Cinerender folder that should allow cinerender to run without issue. I believe Redshift not longer works and the content of that folder causes Cinerender to malfunction.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Make sure you restart Archicad once you have deleted the folder. You will need to do it for all versions you have.
Lee Hankins
macOS Tahoe (26.0)
I tried that as well. No luck. I literally attempted the cineware folder replacement about 10 times. And restarted Archicad after that.
Setup info provided by author
