Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
Copy while offsetting
I would like to make a separate copy of ex. a slab when i choose the offset all edges + CTRL or multiple copies with CTRL+ALT it would be very useful for me a specialy with the slabs having holes inside.
Not needed.
Just use the offset tool and magic wand at the same time and place a new slab.
The multiple offset command can also be used.
TomWaltz
You already can using the offset commands... though it would be nice for the CTRL key to work on the Pet Palette Offset the same way it does with Drag, Mirror, and Rotate.
Tom Waltz
David Maudlin
The multiple offset command works, but will not copy the holes in the original slab, I think this is the feature he wants.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
