Wishes
Dimensions Tool - Geometric Methods
When I select only two points, or points that are all in a line, I wish the Dimension Tool would default to the corresponding Geometric Method for these conditions.
I do not like having to select Horizontal, Vertical, or Parallel, each time I change direction when I have selected only two points.
If the points are not in a row, I can understand the need to specify.
Yes, Essential!. This is one of the many, many, "little" things that make AC "CLUNKY" & FRUSTRATING to use.
This one has been brought up before, but there's no harm in the reminder. This is a small improvement that would save a lot of time.
