Wishes forum
Dimensions Tool - Geometric Methods
Steve Jepson
When I select only two points, or points that are all in a line, I wish the Dimension Tool would default to the corresponding Geometric Method for these conditions.
I do not like having to select Horizontal, Vertical, or Parallel, each time I change direction when I have selected only two points.
If the points are not in a row, I can understand the need to specify.
ArchiCAD 25 6000 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
2 REPLIES 2
Yes, Essential!. This is one of the many, many, "little" things that make AC "CLUNKY" & FRUSTRATING to use.
This one has been brought up before, but there's no harm in the reminder. This is a small improvement that would save a lot of time.
