Place your cursor in any line of code and press 'CTRL+L' to find the line number.
Alternatively type an number in that dialogue and ENTER to go to that line.'
The only time you really need to know the line numbers is when you get an error in Archicad - 'problem at line xxx in object yyy'
The just use CTRL+L to find it.
If you press the 'Check Script' button in the editor it will highlight the line with an error (if you press STOP) - you may just have to scroll up or don in the script to see it - don't click in the script or you will lose the highlight.
