2007-05-04 05:38 PM
2007-05-04 05:42 PM
2007-05-04 06:13 PM
2007-05-04 08:19 PM
Allen wrote:This is not true -- it is the section by which the associated wall/beam/column is extruded. I guess what you're referring to is additional information to be provided in section -- you could make the same case for Composites.
The initial setup of the Complex (Wall) Profiler represents the same in plan view and section view.
2007-05-04 08:25 PM
Allen wrote:For composites, that's true. Not for Profiles. You can add as much detail as you want.
The initial setup of the Complex (Wall) Profiler represents the same in plan view and section view. Use the general information as is for plan view(simple block/fill pattern for brick) . Add more details to the section view....individual bricks/blocks etc...
2007-05-04 08:46 PM
TomWaltz wrote:True -- but you may get some unexpected results in 3D
...for Profiles. You can add as much detail as you want.
2007-05-21 07:49 PM
2007-05-21 09:01 PM
Allen wrote:Ah, well, now you may get some votes -- this (or a version of) has been a long standing wish...
I was actually thinking of composites...
