Wishes
Post your wishes about Graphisoft products: Archicad, BIMx, BIMcloud, and DDScad.
SQL Query Window
It would be helpful if the SQL query capability could maintain more than one IE output window at a time. It would be helpful if the query didn't clear itself every time it gets closed in order to look at something else in ArchiCAD. It might be helpful, too, if errror messages were expanded to be more informative to non-programmer humans.
1 REPLY 1
It would help if the query window never needed to be closed - that is, if it were made a modeless dialog (palette). Being a modal dialog, you cannot even use the Help menu when the dialog is open. This is just plain silly.
One of the forum moderators
