2023-06-12 07:33 PM - edited 2023-06-12 07:34 PM
Wishing for a way to switch from dragging a copy to dragging multiple. When dragging an element, the option key (on Mac) can be pressed to drag a copy or option and command together together to drag multiple. But when dragging a copy by using command+shift+D, pressing option+command should initiate the drag multiple feature....but doesn't. Can we make this a thing? Thanks!
2023-06-12 07:56 PM
You must have custom commands in your settings.
Standard "copy drag" is "cmd+D"
After executing this command, you can switch to single or multiple copies with "opt" or "opt+cmd".
Now...you can actually make any combination of keys for most of the commands...can you solve it that way?
Or just use Move - and set your array style....
2023-06-13 03:21 AM
What keyboard short-cut do you have set up for it.
I believe by default there is none set up.
You can set any short-cut you want in the Work Environment.
2023-06-13 05:36 AM
I have never noticed this. Never use the Drag a Copy hotkey, always just use Drag then toggle between the options. It is odd that the toggles are not available when using those alternates...
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2023-06-13 06:14 AM
I suspect the reason the Cmd+Option toggle is not available after you press Cmd+Shift+D is that when you use that shortcut, you have specifically activated the Drag a Copy function, nothing else.
I feel your pain though - I do what you described all the time.
2023-06-13 07:49 AM
Funnily enough this is an issue that I never thought about. I had to reopen ArchiCAD to see again how I did things myself. I think I experienced this way before earlier during my learning period, I just erased it from my experience. I think this is the main reason why I muscle-memoried into ctrl+D, ctrl ; and not ctrl+shift+D because I could not drag multiple copies after the fact.
2023-06-15 08:26 PM
Yes, I think this may become my learned behavior as well if the option I propose doesn't become a reality. Thanks!
2023-06-15 08:29 PM
Thanks Barry - I could set one up, but the instance I'm talking about is when I switch from the mind set of "I need to make a copy of this" and hit cmd+shift+D, to "oh, shoot, I have to make a bunch of copies". In this instance I have to cancel the command, and then redo it for multiple copies. It's about switching once the "drag a copy" is already in process. Thanks.
2023-06-16 04:27 AM - edited 2023-06-16 04:32 AM
@NateLumen Sorry for my previous reply which this is replacing... Yes, I see what you're saying and I think it is a bug.
If I cmd-D to drag and then press option-cmd, I get the ++ to drag/copy multiples.
If I option-cmd-D to drag a copy, nothing will make the "++" copy multiple appear. Tapping Opt will make the "+" disappear, making it an ordinary drag. Tapping it again adds back the "+" taking us back to drag-a-copy. But no key combination will make the "++" appear... even though option-cmd should do so. I mean, if I've tapped Opt to make the drag-a-copy into an ordinary drag command... then, just like as if I had issued an ordinary drag command, option-cmd should give me "++" for multiples.
If others agree this is a bug, I'll report.
2023-06-19 02:55 PM - edited 2023-06-19 02:56 PM
