Read more
Wishes
GDL - Called Object Parameters
Lingwisyer
Guru
Hi All,
This wish is for the parameters of Called objects to be available to the caller or be automatically added to the callers parameter list.
This would make objects like Rotator more usable as it would expose the called objects parameters for user customisation. It would also make using GS macros more viable as you would not have to copy the million parameters that they use, many of which are not even included in the parent subtype.
Ling.
ps. The GDL update they brought up recently was just UI right?
0 REPLIES 0
