Wishes
Layer window - Show/Hide folder button
JohnJay
Hide and Show folders, like you can with single layers
AC27 | i7990x | RTX4070 | W10
4 REPLIES 4
I think you can already do this. The eye symbol next to the folder shows an open eye if all layers in the folder are shown, a closed eye if all layers are hidden and a half and half if some are hidden and some shown. If you repeatedly click the eye it will cycle through showing or hiding all layers in the folder.
Lee Hankins
ArchiCAD 4.5 - Archicad 27UKI Apple Silicon 27.2.0
macOS Sonoma (14.4.1)
JohnJay
Hmmmm
I don't see an eye next to the folders
No - because who ever developed the UI thought that we should move between the two panes all the time instead of just being able to do things efficiently....
You have to select the layers folder in the top pane so that you see its folders in the bottom pane and then you can change the status of a folder. But just as a shorthand for selecting its content - if a new layer is added to the folder it will not inherit the status...
JohnJay
Thanks - I just saw that and came to post
Unfortunately the list of things that need rethinking/tweaking/finishing, and not to mention fixing, is growing
Learn and get certified!
