ā2022-06-15
04:58 PM
ā2022-06-19
10:04 PM
주방 = kitchen is TEXT
The rest are labels.
ģ·ģ„ = dress room is label
I looked at the mtext value with the autolisp function.
There's too much code for number 3.
(-1 . <Entity name: 2a6485c11c0>)
(0 . "MTEXT")
(330 . <Entity name: 2a65a1219f0>)
(5 . "718C") (100 . "AcDbEntity")
(67 . 0) (410 . "Model")
(8 . "Annotation - LabelPen-6") (62 . 7) (370 . 9) (100 . "AcDbMText") (10 15352.2 1269.96 0.0) (40 . 200.0) (41 . 0.0) (46 . 0.0) (71 . 2) (72 . 1)
(3 . "\\A1;{\\pqc;\\pt0,6000;\\fė§ģ ź³ ė|b0|i0|c129|p50;ģ·ģ„\\fė§ģ ź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0")
(3 . "|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|")
(3 . "p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ")
(3 . "ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|")
(3 . "c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;") (1 . "\\fė§ģ ź³ ė|b0|i0|c129|p50;\\fė§ģ ź³ ė|b0|i0|c129|p50;}")
(7 . "ė§ģ ź³ ė") (210 0.0 0.0 1.0) (11 1.0 0.0 0.0) (42 . 1814.99) (43 . 259.918) (50 . 0.0) (73 . 1) (44 . 1.0))
I looked at the value of mtext generated by autocad as autolisp.
Not 3, but 1, and the amount is too small.
((-1 . <Entity name: 2a65b585ae0>) (0 . "MTEXT") (330 . <Entity name: 2a65a1219f0>) (5 . "7216") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 . "AcDbMText") (10 19846.6 1291.85 0.0)
(40 . 300.0) (41 . 1023.46) (46 . 0.0) (71 . 1) (72 . 5)
(1 . "{\\fGulim|b0|i0|c129|p50;ģ·ģ„}")
(7 . "Standard") (210 0.0 0.0 1.0) (11 1.0 0.0 0.0) (42 . 747.004) (43 . 335.153) (50 . 0.0) (73 . 1) (44 . 1.0))
Is this a bug?
ā2022-06-16 11:38 AM
Do you use the Archicad 25 zone label here? Or which label is this?
It helps the community to understand better what your issue is, so we can give you better advice.
NoƩmi Balogh
Senior Community Expert, Admin
ā2022-06-16 12:19 PM
I have another question, can I do it?
A question about Archicad's policy in Korea.
ā2022-06-16 06:27 PM
On the left, 3 spaces have been erased.
If you export the label, you will get a blank space.
ā2022-06-16
07:19 PM
ā2022-06-19
10:05 PM
I wonder if you guys used code 3?
Lisp, which removes whitespace from Mtext used by autolisp, doesn't work either. It works only after clicking once on the Mtext you created in CAD.
This is original dxf code
(3 . "\\A1;{\\W0.750000x;\\pqc;\\pt0,76000;\\fėėź³ ė|b0|i0|c129|p50;W2B\\fėėź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\A1{\\H.66x;\\S^ ;}\\fėėź³ ė|b0|i0|c129|p50; \\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fė") (3 . "ėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i") (3 . "0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p") (3 . "50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ") (1 . "ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;\\fėėź³ ė|b0|i0|c129|p50;}")
This is the dxfcode changed after clicking.
(1 . "\\A1;\\pxqc,t0,380;{\\W0.5625;W2B\\H0.66x;\\S^ ;\\S^ ;\\H1.51515x; }")
Value is W2B
ā2022-06-21 10:12 AM
No answer, so I'm asking again.
