‎2015-07-16
10:21 PM
‎2023-05-19
03:55 PM
Gordana Radonic
‎2015-09-02 02:15 AM
svenl wrote:With the Label Tool active, on the Info Box, right after the Layer Selection button. It is called the Label Type field.laszlonagy wrote:I don't see a place to set this.
The Label Tool has two Geometry Methods: Associative and Independent. You should use the latter.
‎2015-09-02 04:30 PM
laszlonagy wrote:This does not appear in my info box where you describe it. But I have found a section called "geometry method" which solved the problem. This button appears further down in the info box. Selecting "detailed" works like the old tool.svenl wrote:With the Label Tool active, on the Info Box, right after the Layer Selection button. It is called the Label Type field.laszlonagy wrote:I don't see a place to set this.
‎2015-09-02 04:53 PM
‎2015-09-02 05:00 PM
laszlonagy wrote:Just to clarify. You can also label Curtain Wall members directly using the associated labels, if you press "tab" then you cycle between labelling the members vs the whole CW.
...because Curtain Wall Member Labeling is now done by the Document\Document Extras\Label Curtain Wall Members menu command.
‎2015-09-16 09:06 PM
‎2015-09-16 10:53 PM
‎2019-01-28 08:36 PM
another Moderator
