Missing Model View Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2021-01-29
10:53 PM
2023-05-23
12:09 AM
Gordana Radonic
However, for example, I noticed that I had views where door or window callouts should be off but they were showing. I open the MVO to check it, and everything is set correctly. The only fix that I can find, so far, is going into View Settings clicking off of Floor Plans, then back on it, refresh the layout view, and it fixes the callout. Close the file, come back in, rinse, repeat, ...
Red
i7 8700k
ROG Strix Z390-E MoBo
64gb RAM
EVGA GeForce GTX 2080
_______________________
http://www.facebook.com/flatcreekdesignstn
http://www.sraarchitects.biz
Solved! Go to Solution.
- Labels:
Layouts
Model View Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2023-12-05 03:30 PM
Thanks for the reply and advice! We will implement this solution and let you know how things go.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-03-07 06:23 PM
I use AC 26 and i'm dealing with the same problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-06-14 05:02 AM
I'm still encountering this issue with Archicad 27 build 5030int.
ArchiCAD 9 onwards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-06-19 12:29 PM
Was your project migrated to Ac27 or started in Ac27?
Also, is it a solo or Teamwork project?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2024-06-24 12:14 PM
started with AC27 and its a teamwork (BIMcloud Basic) project
ArchiCAD 9 onwards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2 weeks ago
I am having a very similar issue with BIMcloud, I would like to revive this thread.
Specifically, in files we work in on Teamwork (BIMcloud), the view settings will seemingly randomly change the MVO. We had issues with MVOs going missing in previous versions, and it was a known glitch, but it seems that now the problem is the MVO will just change on its own. One day I will publish drawings and they will look correct, and the next time I go to publish things will randomly change.
One note, we work off of a template that was originally developed in AC22 (or previously possibly), is it possible that the glitch is built into our template? Otherwise we are currently working in AC28, we keep up on the latest builds.
2021 MacBook Pro 16" 32GB Apple M1 Max
MacOS Sonoma 14.6
- « Previous
- Next »
- « Previous
- Next »
