We value your input!
Installation & update
External monitor scales some elements
kathrinev
Hi!
My external monitor scales certain elements in Archicad in particular. It does this every time I use my monitor, no matter if I reboot or reconnect and no matter which AC version I've used. I have tested the resolution and scaling in Windows, but nothing helps. The weird thing is, text and icons are perfectly sized, but my scroll bars are HUGE. Also, it won't let me scroll the overhead toolbar, so there are certain tools I can't use unless I pull AC over to my laptop screen (where everything looks normal).
This is mostly a problem in Archicad. In Adobe, everything is scaled okay, except my cursor is enormous when working in Indesign or Illustrator. Also, my Windows taskbar is unnecessarily big.
Nothing I have seen on Windows forums have been of any help, so I wondered if any of you know how to customize sizes in Archicad or know a solution to this?
5 REPLIES 5
kathrinev
It also happens to the title and the scroll bars in the Teamwork Palette, but the rest of the palette is fine.
I would suspect a Windows setting for accessibility or maybe a theme?
But I am not sure why it would affect just your external monitor and not every application.
Marc H
It may be settings, but if not, I'll relate a similar esoteric issue I had a few years ago with (Windows based) MS Access when running it on a large, high-resolution, extended monitor. (In this case, it was enormous checkboxes showing within input forms. Everything else was normal size.)
My research turned up that some software code is/was 'hard-coded' to launch on specific display specifications.  I used a workaround wherein I would open the application on my 'home' (device) screen, then drag the session window over to the external monitor for use.  It was kind of inconvenient, but it worked.  If this is the case, you may want to relate the issue to GS.
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC27 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Sonoma OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
Rubia Torres
Hi @kathrinev,
If the previous replies cannot solve your problem and it requires deeper investigation from the Graphisoft team, please contact your local distributor. You can find their contact information here: Get in Touch – Graphisoft.
Regards,
Rubia Torres
Community Specialist | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
kathrinev
Thank you for your replies! Nothing has worked so far, so I'll contact Graphisoft and see if they have a solution.
