2023-05-03 02:25 AM - edited 2023-05-03 02:34 AM
The left side is the same type of wall
The right side is an L shape with two identical walls.
Left 4 wall and right 2 wall
right 2 wall
this is my best
Solved! Go to Solution.
2023-05-03 03:31 AM
Read here,
https://www.onland.info/archives/2010/07/fixing_wall_corners_with_columns.php
another Moderator
2023-05-03 03:31 AM
Read here,
another Moderator
2023-05-03 03:46 AM
Thank you so much. ^^
Re: Intersection Issues - Graphisoft Community
How Walls are Connected in Archicad - Graphisoft Community
2023-05-03 02:21 PM
If Building Materials have the Intersection Priority correcly set-up, that intersection should be cleaned automatically.
In most cases it helps to move the Reference Line next to one of the Core lines and keep that rule consistent.
