We value your input!
Is there a technique when 4 walls meet at one point?
LeeJaeYoung
The left side is the same type of wall
The right side is an L shape with two identical walls.
Left 4 wall  and right 2 wall
right 2 wall
this is my best
AC27 on window 11
Eduardo Rolon
Read here,
https://www.onland.info/archives/2010/07/fixing_wall_corners_with_columns.php
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Eduardo Rolon
Read here,
AC27 US/INT -> AC08
another Moderator
LeeJaeYoung
Ernest Atanasiu
If Building Materials have the Intersection Priority correcly set-up, that intersection should be cleaned automatically.
In most cases it helps to move the Reference Line next to one of the Core lines and keep that rule consistent.
arch. ernest atanasiu
AC 10-26 INT/GER/FR on Win 10/ Win 11
