LeeJaeYoung
Is there a technique when 4 walls meet at one point?
The left side is the same type of wall
The right side is an L shape with two identical walls.
Left 4 wall  and right 2 wall
right 2 wall
this is my best
AC27 on window 11
1 Solution
Eduardo Rolon
Read here,
https://www.onland.info/archives/2010/07/fixing_wall_corners_with_columns.php
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
3 Replies 3
Eduardo Rolon
Read here,
AC29 US/INT -> AC08
LeeJaeYoung
Ernest Atanasiu
If Building Materials have the Intersection Priority correcly set-up, that intersection should be cleaned automatically.
In most cases it helps to move the Reference Line next to one of the Core lines and keep that rule consistent.
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 10/ Win 11
