Sandwich Panel
Kikoria
Hi everybody. I was wondering, can I create sandwich panel by using wall tool?
The panel looks like this:
I built it using railing tool. It was easy, but I couldn't create an opening inside of it. Then I tried to dig into log wall but couldn't get the desired result. Is there any way in the wall tool to make sandwich panel like this?
Thank you in advance!
Kind regards,
Tamaz Kikoria
Architect
Technical Examination and Design Department
GEORGIAN WATER & POWER
17 REPLIES 17
I don't think they work with the accessories.
I would assume they are stand alone objects that you just have to put in place.
When you get them from BIMObject, does it say how you are supposed to use them?
I don't have a BIMComponent login so I have not downloaded any.
I would assume it is just an object that you can change the size of.
Maybe @mija can expand on how to use them with an accessory add-on?
Got it, thanks. But if we use accessories as sandwich panel modelling tool, how can we use it? there are only certain tools in accessories library and there's no sandwich panel-like thing in there.
Kind regards,
Tamaz Kikoria
Architect
So this is how I use them..
I downloaded the first one from this manufacturer https://www.bimobject.com/en/europerfil/product/atica_1100_pur
  • Add it to your Library manager
     Draw a wall, select it and follow the path
     select your panel and customize it as you want
  • Then your cursor  will be like an angled eye so you select on which side of the wall you want your panel (sorry, dont know how to screenshot the cursor)
     Taa-daa
  • When adding windows/doors you place them to the main wall like this mija_4-1688385075112.pngmija_5-1688385083726.png
  • accessories will follow any modification of the wall
  • You can play with other libraries and objects from  bimobject website, but they pretty much work the same.
Hope this helped!
Archicad 26, build 3001
Montenegro
Also when I have only sandwich panel as my wall, I use air building material wall with 1cm thickness. And when I am finished I change it to 0cm so it's not visible. Then accessory will not follow the wall modification since it has no thickness.
So make sure it has when you are adding windows or doors etc.
Montenegro
Erwin Edel
Alternative solution:
  • a simple composite with the outer layer as the max. thickness of the panel:
  • a whole lot of columns on a hidden layer with a building material that has higher priority than the outer skin to punch holes
    resulting in:
    I use columns since they automatically clean up with walls.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Thank you!
Kind regards,
Tamaz Kikoria
Architect
Thanks a lot!
Kind regards,
Tamaz Kikoria
Architect
Thanks Mija.
So it is created as a wall accessory object.
I thought it might have just been a static object that you had to place and multiply.
Much better that is is actually an accessory object itself.
