Project data & BIM
Best practices for attributes, schedules, templates, favorites, hotlinks, and more
Articles
There are a lot of cases – even if it is not entirely intentional when you migrate projects. This happens when content made in an earlier version of Archicad is opened in a newer version. These scenarios can include: simple copy-paste from your old projects hotlinking conten...
  • 7859 Views
  • 0 likes
  • 0 comments
The ArchiCAD 10 file converter allows users to migrate their files versions 6.5, 7 and 8 to ARCHICAD 10. This file can then be opened in the current version of the software. If you have already installed the ARCHICAD 10 file converter please navigate to the steps further dow...
  • 5861 Views
  • 0 likes
  • 0 comments
Please follow the steps below to install the ArchiCAD 10 File Converter on Windows. 1. Visit the link below. https://www.graphisoft.com/downloads/fileconverter.html 2. Download the correct language version (US or international) of the ARCHICAD 10 Converter Package for Window...
  • 12125 Views
  • 0 likes
  • 0 comments
Please follow the steps below to install the ARCHICAD 10 File Converter on Mac OS. 1. Visit the link below. https://www.graphisoft.com/downloads/fileconverter.html 2. Download the correct language version (US or international) of the ARCHICAD 10 Converter Package for macOS. ...
  • 6091 Views
  • 0 likes
  • 0 comments
File Compatibility • ARCHICAD 27 and newer versions can open PLN files back to version 17. • ARCHICAD 26 and earlier versions can open PLN files back to version 8.1. • ARCHICAD 6.5, 7.0 and 8.0 files may be opened in the ARCHICAD 10 file converter. Once a copy is saved to ve...
  • 8136 Views
  • 3 likes
  • 0 comments
ARCHICAD can back-save project files in the previous ARCHICAD version. As example if you have an ARCHICAD 21 project, you can save it back to ARCHICAD 20 but not to ARCHICAD 19. To back-save: Use File > Save as… In the Save dialog box, choose ARCHICAD xx Project from the Sav...
  • 26457 Views
  • 0 likes
  • 0 comments
You can choose from the below listed Archicad File converters to convert your Archicad files to a format which is supported by current Archicad versions. The latest Archicad File converters can be find on Graphisoft.com. You can also find the FAQ on installation, platform an...
  • 30636 Views
  • 1 likes
  • 0 comments
