Visualization
Cineware renderer quits in ArchiCAD 28
svpribyl
I just downloaded and installed ArchiCAD 28 and I get the same message regarding Cineware rendering engine quitting that I got with the 28 Technology preview:
Operating system used: Mac Intel-based
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
44 REPLIES 44
Marthar K_ Byomire
This is the error i am getting when i start Archicad. Even before i open the settings for rendering.
ArchiCAD 27
MacBook Pro 16-Inch, 2019
2.3GHz 8-core Intel Core i9
16GB RAM 4GB AMD Radeon Pro 5500M
Try deleting the folder plugins from the Cineware folder.
this will of course lead to redshift not working, but cineware should be OK
From Archicad 17
MacBook Pro M1 Max
Marthar K_ Byomire
How do i fix the Redshift issue? It is rather important as Cineware takes a while to render.
ArchiCAD 27
This solution no longer works on my machine. Can Graphisoft please provide a solution?
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
Thank You!
Hi there,
This link no longer works - would someone be able to uploaded a 'working' Cineware Folder please?
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
The link does not work for me, I get the message:
"Invalid Link
The link you are trying to access does not exist."
I am getting this same alert. Graphisoft, I would be embarrassed if I ran a company the size of yours and could not address this situation that has been going on for about a year. Please solve it, and not with a workaround!
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
Could you please repost this file? I cannot open this website.
I accidentally moved the file to the bin and now cannot render anymore.
Thank you!
Karel Landa
Hi all,
if you still have problems with cineware, please read this article from Graphisoft about know issues in macOS 15 where this problem is adressed including a new link for download.
From Archicad 17
MacBook Pro M1 Max
Setup info provided by author
