I would like to see a set of consistent parameters applied to every object. Mostly concerned with the graphical representation of the objects, pen #, fill # in both 2d & 3d aswell as the ability to turn each element on or off.
for example 'Multi Handrail' has a 2d contour pen, but no 3d pen which is stuck on pen 1 (unless the Enable Object's Pens is not ticked). Also the posts show on the floor plan which at 1:100 are not readable.
Also i think it would be good if the 'parameters tab' was upgraded graphically to look like the 'custom settings' tab. Furthermore the consistent set of parameters could be in the parameters tab and object specific parameters in the custom settings tab.
