2013-09-11 10:26 AM
| Archicad 4.55 - 27
2013-09-11 11:15 AM
2013-09-11 12:09 PM
Barry wrote:Now this one I didn't know, in spite of considering myself to be an experienced Archicad user. Thank you for sharing this. But still this is just one small step towards the good solution. I'd rather have, maybe in the dimensioning dialog window, one option for using offset placement, where one could put the offset value in. The whole procedure would be almost the same, where you click on the points to be measured, then click to choose the dimensioning line orientation, (which would also become the origin for the offset!), and after that you would choose the side of the offset placement (like WE USED TO DO when inserting windows, where you could choose left or right - I still don't understand why this is not possible anymore). You could also keep the traditional measuring placing method as the default option, I wouldn't mind that.
Notice the +/- is after the number - this will add or subtract the distance from the current cursor position rather than from the origin.
If you don't put the +/- after the number the distance will be measured from the user origin.
| Archicad 4.55 - 27
2013-09-11 06:30 PM
2013-09-14 09:12 PM
4 weeks ago
It has been more than 10 years since my original post of this wish.
No news in the dimensioning toolset, still has to be done by typing in the offset value.
Would anybody else like to have a better solution, or is it just these few people here?
| Archicad 4.55 - 27
