Read more
Wishes
Import Attributes from a Teamwork file
Attribute manager should be able to import attributes from a Teamwork file.
13 REPLIES 13
__archiben
more than that: attribute manager ought to be able to import attributes from a template file!!!
all the more reason for a combined, single file-format ala professors lohden's big wish.
~/archiben
b e n f r o s t
attributes and VIEWS, too!
Ben Odonnell
~/archiben
I belive that this is quiet a large issue, or has it just been over looked! I don't normally like to stick my chin out regarding programming, as I'm no programmer my self, therefore know very little about it, but if you can take a pln file and simply change the .pln extention to .tpl to get ArchiCAD to read it as a template, how hard can it be to put the .tpl into the Attribute Manager list?
BTW, if you have an existing *.tpl file and want to load it into Attribute Manager, simply change the tpl extension to pln then you will be able to load it in Attribute Manager. Please note that this is a work around.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
__archiben
yeah - i know. but not to be able to read attributes from a template file without any [censored] around is quite frankly embarrassing!
~/archiben
b e n f r o s t
Ben Odonnell
Couldn't agree more.
It has to be fixed ASAP.
Cheers.
Ben
Ben O'Donnell
__archiben
so why didn't you report it back in beta then?
~/archiben
b e n f r o s t
Ben Odonnell
Wooooooot,
Me? you were/are the master MR NR 1:D To be honest with you I can't remember even using AM under the beta test What a miss!
Oh well can't be every where.
Cheers.
Ben
Ben O'Donnell
__archiben
Ben wrote:
Wooooooot,
Me?
"could try harder" mr odonnell!
make sure you get it next time, eh? or i'll still be no. 1 . . .
b e n f r o s t
Ben Odonnell
lol ,
Isn't it past your bed time Mr Frost? Just wait till ArchiCAD 10 beta
Cheers.
Ben
Ben O'Donnell
